Report Configuration
The Report Configuration page allows users to create new or edit existing reports to be used with the Reports page, or widget drill-downs.
Creating a New Report
Click the New Report button to bring up the New Report dialog and give the new report a name.
Enter a name, description (optional) and the width of the dashboard or report and choose the type by selecting one of the radio buttons then click Create to generate the dashboard or report.
The new report will be added to the Report Selection treeview, and the Report Configuration pane will populate with the default report attributes. The values can be changed by double-clicking on the Value cells. Pressing the Reset to Defaults button will revert any changes to the default values.
Most options are self-explanatory, but a couple that may be of interest are:
Unlock and Edit Report
To add content to the report, click the Unlock and Edit Report button.
All reports in the list can be edited from Report Configuration, by selecting them individually from the Report Selection treeview.
