New in PLAXIS 2D/3D Output Viewer 2024.3.1
Release: July 2026
The PLAXIS 2D/3D Output Viewer Version 2024.3.1 contains the following improvements and updates compared to PLAXIS Output Viewer 2024.2:
PLAXIS 2D and 3D Output Viewers are available free to use. The PLAXIS Output Viewer is a standalone application intended for viewing and inspecting the results of a fully calculated PLAXIS model. This application helps you accelerate approvals and reviews by allowing project reviewers, consultants, or clients to provide feedback quickly, without the need to own or use a commercial PLAXIS 2D or PLAXIS 3D license.
