PLAXIS 3D 2024.3 Release notes
New in PLAXIS 3D 2024.3.1
Release: July 2026
PLAXIS 3D 2024.3.1 (24.3.1.12) contains the following improvements and updates compared to PLAXIS 3D 2024.2:
Compatibility notes: Due to the major changes in the material database and the unit system, PLAXIS 3D 2024.3 will be installed alongside Version 21, instead of overwriting it. When opening PLAXIS 3D V21 projects with PLAXIS 3D 2024.3, projects will automatically be saved as a converted copy with the _converted suffix and will require recalculation. When using non-SI-units, the mesh also needs to be regenerated.
The PLAXIS 3D CONNECT Edition V21 projects will remain unchanged.
Earlier versions of PLAXIS will not be able to open files saved in PLAXIS 3D 2024.3.
New features
Design Approaches
With Design Approaches users can store, manage and apply sets of partial factors in a general way in their analysis. Previously available in just PLAXIS 2D, this now allows users to apply modelling principles considering partial factors for soils and loads, to follow Eurocode or LRFD, and more easily set up SLS and ULS analysis in PLAXIS 3D projects. Only available in Advanced and Ultimate tiers.
Improved version handling and file updater
The new conversion facility is included for projects that were created in earlier versions. This provides users a more robust experience than before when opening old projects in new versions of PLAXIS, reducing the risk of data loss and properly converting modified properties. Additionally, this new tool can also help users determining in which PLAXIS version the project was originally created or calculated. The new conversion facility supports the conversion of projects from PLAXIS 2D 2017 and later.
Other changes and improvements
Fixed issues
A large number of issues have been addressed, including:
Download links
You can update to the latest version using the CONNECTION Client or download the installer via Bentley System's Software downloads.
