New in PLAXIS Monopile Designer 2024.3.1
Release: July 2026
PLAXIS Monopile Designer 2024.3 (24.3.1.12) contains the following improvements and updates compared to PLAXIS Monopile Designer 2024.2:
Compatibility notes: Due to the major changes in the material database and the unit system, PLAXIS 2024.3 will be installed alongside Version 21, instead of overwriting it. When running the calibration, GeoDS-projects created with PLAXIS CONNECT Edition 3D Version 21 will automatically be saved by PLAXIS Monopile Designer as a converted copy with the _converted suffix.
The PLAXIS CONNECT Edition V21 projects will remain unchanged.
New features
Modal analysis of monopiles (General Availability)
Calculate natural vibration frequencies and vibration modes for the monopile-tower-nacelle system. The rotor-nacelle assembly is modelled as a lumped mass. Soil-structure interaction can be considered through the initial stiffness of the soil reaction curves or ignored by specifying a ‘clamped’ condition.
Design space visualisation
To assist Calibration it is now possible to visualise the specified geometry data sets in a normalised L/D-h/D space.
Additional parameters for sands
Cohesion (c’) and the exponent of the stiffness depth-dependency relation (m) can now be specified for sand profiles. The previous default values c’ = 0.1 kPa and m = 0.5 will be automatically applied to existing projects.
Other changes and improvements
- Added support for tapered monopile sections in 3D design verification models.
- Calibration model charts are now grouped by Soil Profile, enabling visibility toggling for the whole group.
Fixed issues
A large number of issues have been addressed, including:
- SOLVED Known Issue: Updated PLAXIS to align with the new Windows security update initially introduced in KB5083631, ensuring projects open reliably again without workarounds. [more info]
- [1473334] Implicit fixed values for sand materials for c' and (power) m could lead to inconsistent derived values. These parameters are now made explicit.
- [1533385] In some rare cases, starting PLAXIS Monopile Designer would get stuck in the license checking mechanism and finally crashed. This is now resolved.
Download links
You can update to the latest version using the CONNECTION Client, or download the installer via Bentley System's Software downloads.
