Note: Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Reference Information> Code Compliance Calculations> select a piping code to see the calculations performed by AutoPIPE.
Comments, Questions, and Answers about Boiler & Pressure Vessel Code, Rules for Construction of Nuclear facility Components Division 1, Subsection NCD, Class 2 and Class 3 Components:
- SIF calculation for Socket weld joint
Equation 11 not defined in Stress Summary dialog and where are the results
- Pressure Stiffening applied
