Question:
When analyzing a model in AutoPIPE Vessel the following warning number was reported.
232 CHECKING DATA : Foundation height = xxxx in , by default.
Why and how to avoid it?
Answer:
This warning message indicates that the user has not specified an elevation (Level of Base Plate from the ground).
Consequently, the software assumes a default foundation height of 300mm (11.811 inches) , which is used in wind and seismic calculations.
Enter appropriate foundation height to avoid this warning message.
