List of critical and high severity defects identified in STAAD.Pro V2024 build 24.00.02.354
| Issue ID | Title | Severity | 1st affected Build | Fixed in Build |
| A-524650 | Member section displacement results do not account for lateral releases on members | 2 - High | 20.07.04.12 | Known Issue |
| A-1484993 | Incorrect Zone Loading on Members with Beta Angle | 1 - Critical | 23.00.00.345 | 25.00.00.539 |
| A-1617236 | Incorrect Re-Initialization of Some Steel Design Parameters | 1 - Critical | 24.00.00.577 | 25.00.00.539 |
| A-1568149 | Mass overestimation due to improper load placement in dynamic load | 1 - Critical | 20.07.08.20 | 25.00.00.539 |
| A-1674513 | AISC 360-16/22: Incorrect interaction ratio reported when both H1.1 and H1.3 apply | 1 - Critical | 21.00.01.12 | 25.00.00.539 |
| A-1667479 | IS800-2007 (LSD): Incorrect λLT Calculation for Wide Flange Profiles | 1 - Critical | 20.07.06.23 | 25.00.00.539 |
| A-1674510 | AS 4100: Incorrect bi-axial interaction check when axial limit governs (Clause 8.4.5) | 1 - Critical | 20.07.04.12 | 25.00.00.539 |
| A-1684835 | GB50017-2017: UPT Wide Flange Profile | 2 - High | 24.00.02.354 | 25.00.00.539 |
| A-1708628 | AISC 360-16/22 : Double Channel Front-to Front specification | 2 - High | 21.00.01.12 | 25.00.01.424 |
| A-1708762 | Mexican Legacy Database | 2 - High | 20.07.04.12 | 25.00.01.424 |
| A-1716778 | EN 1993-1-1: Incorrect Section Classification | 1 - Critical | 20.07.06.23 | 25.00.01.424 |
| A-1716791 | EN 1993-1-1 2005 : Effective Section Properties of Wide Flange Sections | 1 - Critical | 23.00.02.361 | 25.00.01.424 |
| A-1717898 | EN 1993-1-1: Wide Flange with SET Z UP | 1 - Critical | 24.00.00.577 | 25.00.01.424 |
| A-1468910 | Self weight loading on plates with variable thickness | 2 - High | 20.07.04.12 | 25.00.01.424 |
| A-1708447 | AISC 360-2016 and 2022: Double Unequal Angles with Short Legs Connected | 2 - High | 21.00.01.12 | 25.00.01.424 |
| A-1739410 | NRC/NBCC 2010: Incorrect Evaluation of Minimum and Maximum Base Shear for Static Seismic Loading | 1 - Critical | 21.00.00.57 | 25.00.01.424 |
| A-1739748 | Steady State Analysis: Applied Joint Moments | 1 - Critical | 21.03.00.146 | 25.00.01.424 |
| A-1929912 | AISC 360-16/22: Incorrect LTB for Tee and Double-Angle | 1 - Critical | 21.00.01.12 | 25.00.01.424 |
| A-1708470 | Deflection Checks On Cantilevers Including Load Cases With No Local Deflection | 2 - High | 22.08.00.175 | 25.00.01.424 |
| A-1745990 | GB50018-02: Design of Hat Profiles | 2 - High | 24.00.02.354 | 25.00.01.424 |
| A-2007070 | Time History defined with harmonic forcing function having non-zero phase angle | 1 - Critical | 22.12.00.142 | 26.00.00.340 |
| A-1988266 | Seismic self weight calculation for very short tapered I profiles | 2 - High | 21.00.02.30 | 26.00.01.491 |
| A-2038944 | Incorrect member design forces using an SRSS combination | 1 - Critical | 21.00.00.57 | 26.00.00.340 |
| A-2084603 | AS4100 (1998/2020): Incorrect web slenderness limit for Tee profiles | 1 - Critical | 20.07.04.12 | 26.00.01.491 |
| A-2094654 | AISC 360-16/22: Incorrect default SNUG value for built-up members | 1 - Critical | 21.00.02.30 | 26.00.01.491 |
| A-2106652 | CSA S16-09/14: Limiting value of Factored Moment Resistance (Mr) as per Clause 13.6(a)(i) | 1 - Critical | 20.07.10.41 | 26.00.01.491 |
| A-2009553 | Wind Load assignment Combining RANGE and LIST methods | 2 - High | 20.07.04.12 | 26.00.01.491 |
| A-2016637 | AISC ASD: Incorrect Section Modulus used in design of multiple angle profiles | 1 - Critical | 20.07.08.22 | 26.00.01.491 |
| A-2017394 | Local deflection checks of models distant from the global origin | 2 - High | 20.07.04.12 | 26.00.01.491 |
| A-2024531 | Incorrect open-structure wind loading for angle profiles | 1 - Critical | 20.07.04.12 | 26.00.01.491 |
| A-2092167 | Incorrect processing of floor load within a reference load case | 1 - Critical | 20.07.08.20 | 26.00.01.491 |
| A-2011909 | EN1993-1-1-2005: Section classification check is skipped | 2 - High | 20.07.06.23 | 26.00.01.491 |
| A-2125826 | IS 1893 (Part 1) 2016: Incorrect static base shear used for comparison with response spectrum base shear | 2 - High | 21.03.00.146 | 26.00.01.491 |
| A-2017710 | Enclosed Zone Load with disconnected regions | 2 - High | 23.00.00.345 | 26.00.01.491 |
| A-1996410 | AS 4100-1998/2020: Reference Buckling Moment underestimated for UPT wide-flange profiles | 2 - High | 23.00.02.361 | 26.00.01.491 |
| A-2083883 | Connection Design Workflow: Error in re-designing connections | 1 - Critical | 24.00.00.577 | 26.00.01.491 |
