SACS Collapse Solution KB
This contains SACS wikis related to the SACS Collapse program.
Warning: Brace not properly located
Shock cells in SACS Collapse
Viewing Collapse Graphs
SACS Collapse Advanced
Simultaneous Collapse Run
Defining materials using Collapse advanced
Advance collapse with PSI Issue
Collapse Base Shear Calculation
Termination of Collapse Analysis
Spring Reactions in Collapse Output
Negative load factor in Collapse run
Reaching convergence In Collapse Analysis
Model Gap Elements with PSI using Collapse
Reduce Run time for Collapse Analysis
Joint Strength Report using Collapse advance
Inconsistencies using members with the same joint at the start and end in Collapse Module
How to Perform Non-Linear Blast Analysis in Bentley SACS
Joint Selections to Include Flexibility
Input for Elasto-plastic behavior (dented sections)
Strain Results
Defining Ship Indentation Curve for Ship Impact Analysis
Grout dented members
Selection of Software for Non Linear modeling requirement as per DNV
Limits for Deflection Ratios
Ship Impact Force
Pile Head Reactions in Collapse Analysis
Override Member Properties
Member Dent Depth Limit
Plastic Ratio
Warning using Joint Flexibility
Joint Flexibility
'Pile Nearing Punch Through' Warning in Collapse Analysis
Wave loads comparison between analysis
Compressive Strain in SACS Collapse
Joint Strength Result after collapse (after Chord failure)
Grout Labeling in Standard collapse
Defining Multilinear Plastic Material in Collapse
38.
*** INFO: Maximum deflection for joint XXXX has been exceeded for degree-of-freedom DX
39.
Unity Check on Collapse CSF
40.
Member Internal Forces - Static vs. Collapse Analysis
41.
*** INFO: The onset of pile Pull-out has occurred on the pile located at joint 'XXXX'
42.
Member Out-of-Straightness Ratio
43.
Corotational 2nd-order terms
44.
CLPOP2 - Override Member Properties
45.
IMPACT card
46.
DNV C204 Edition for Ship Indentation Curve
47.
Error: Collapse Internal File has been corrupted
48.
Collapse Load Sequence
49.
IMPACT Line Usage and Dent Energy Limitations
50.
Post collision assessment
51.
FAQs Using Collapse Module
52.
Ship Impact Energy Absorption in Collapse Analysis
53.
Out of Straightness in Collapse Advanced
