Display on map doesn't update SNBI fields
Introduction
When an inspector selects to add a map location, via display on map, the NBI fields update, but the SNBI fields do not. How can we correct this?
Instructions
Map coordinates are controlled in the internet properties (Bentley can assign the field IDs to the map coordinates).
An administrator could switch to the SNBI field IDs in the future, but if both are required, a simple calculation where 230105 = 200106 is feasible.
Changing the map coordinates would update the calculation. The format control of SNBI is based on the FHWA guidelines. For NBI (fed tape) submissions, each site is different, and there is a conversion for submission.
