| Product(s): | AutoPIPE |
| Version(s): | ALL |
| Area: | Readme |
| Date Logged & Current Version |
Feb 2025 23.00.02.024 |
| What is New & Changed in AutoPIPE® |
The following outline identifies new features and enhancements in the AutoPIPE 2023 Edition Minor Update 1 version 23.00.02.024.
| AutoPIPE® Requirements |
More detailed installation information can be found in the AutoPIPE Quick Start Guide.
| Product | AutoPIPE |
| Version | 23.00.02.024 |
| Released | 02/21/2025 |
| Language |
| PCF Translator | 1.3.2.024 |
| PDS Translator | 6.0.0.028 |
| ADL Pipe Translator | 1.0.0.035 |
| ME101 Translator | 1.0.0.014 |
| Structural Property Catalog | 10.00.00.015 |
| Bentley DGN Preview Handler | 10.17.01.556 |
| Bentley DGN Thumbnail Provider | 10.17.01.11 |
| iTwin Analytical Synchronizer | 23.01.09.031 |
| iTwin Service Add in V2 | 2.6.1.1 |
| Connection Client | 24.01.00.23 |
| Microsoft SQL Server Compact 3.5 SP2 | 3.5.8080.0 |
CD drive or access to the Internet required for product installation. The minimum system configuration for installation:
| Operating System |
Microsoft Windows 10 x64 Professional or higher |
| .NET Framework |
4.8.1 |
When installing the product through the installer program, the required components will be installed automatically. The contents of the Desktop Prerequisite Pack include:
NOTE: AutoPIPE uses the following fonts on dialogs and in reports. These fonts are pre-installed with Microsft Windows. If any of these font are missing, the text on dialogs and in reports may appear smaller/larger than usual. To install missing fonts, please repair or reinstall Microsoft Windows.
The minimum recommended workstation profile for running AutoPIPE is:
| Memory | 4 GB recommended. More memory almost always improves performance, particularly when working with larger models. |
| Hard Disk | 4 GB free disk space (not including Restore Point space requirements). |
| Video Graphics Card | Any industry-standard video card which supports OpenGL 3D graphics. |
| ProjectWise |
ProjectWise Server 10.00.03.299 with ProjectWise Explorer 10.00.03.453, Note: ProjectWise Server and ProjectWise Explorer are only required if Bentley's ProjectWise is used to manage project documents. |
| OpenPlant Isometrics Manager |
CONNECT Edition Update 11 - 10.11.00.175 Note: Users can use OpenPlant Isometrics Manager (OPIM) to review Stress Isometrics created by AutoPIPE without an entitlement for OPIM, provided they are opened from within AutoPIPE. Direct use of OPIM without an entitlement will log usage and may lead to charges. Click here for more information. |
Word processing, |
Compatibility is more streamlined with Microsoft® Office 64-bit. Please refer to this wiki here for installing AutoPIPE on machine with Microsoft® Office 32-bit. |
| Download and Installation |
See the AutoPIPE Quick Start Guide (..\Documents\Quickstart_AutoPIPE.pdf) for more information on downloading and installing AutoPIPE.
To complete the licensing process, you must have the appropriate roles assigned by your Site Administrator. If you have not been assigned these roles, you will need to obtain the name of your Site Administrator by submitting a Service Request at http://apps.bentley.com/srmanager/ProductSupport.
If you are experiencing problems logging into your Bentley account, please contact Bentley at 1-800-BENTLEY (1-800-236-8539). Outside the United States +1 610-458-5000.
Network Considerations - Network drives are only supported for data files.
- AutoPIPE software must be installed on a local client workstation.
- AutoPIPE data files (*.DAT) must have full read/write access to be opened and edited.
| Applications Included in the Installation Package |
AutoPIPE Standard, AutoPIPE Advanced, AutoPIPE Nuclear, and add-ons are installed from one executable.
NOTE: For further information on translators, please refer to their respective readme files.
| AutoPIPE Functionality for QA Approvals |
| Documentation |
Program Help: Detailed feature information may be accessed directly from the calling application by selecting the Help command, or by pressing the Help button from any of the application dialogs. Be sure to explore the program Help for answers to your questions. A set of supplemental How To, Tutorial, and Reference Information documents in PDF format are provided in the Supplemental Documentation folder (Bentley AutoPIPE > Supplemental Information) of the main Program Help file (autopipe.chm).
Tutorials: Documentation for AutoPIPE applications is provided online in the Adobe.pdf format. These files are accessible from the Help Menu. All documents can be browsed, searched, or printed with the Adobe Acrobat Reader. Information and how to download a FREE copy of the Adobe Acrobat Reader can be obtained from http://www.adobe.com/.
It is highly recommended that you obtain the latest version of the Adobe Acrobat Reader.
| Piping Codes |
This sections contains the list of piping codes, code editions supported and AutoPIPE license edition (Standard, Advanced or Nuclear) for which these items are supported.
| Piping Code | Description |
| B31.1 Power | Power Piping |
| B31.3 Process Piping | Process Piping |
| B31.4 Liquid Trans. | Liquid Transportation Systems for Hydrocarbons, Liquid Petroleum Gas, Anhydrous Ammonia and Alcohols |
| B31.8 Gas Trans. & Dist. | Gas Transmission and Distribution Piping Systems |
| EN 13480 | European Piping Code for Metallic Industrial Piping |
| General | General Piping Code |
| ASME B31J |
Stress intensification factors, flexibility factors, and sustained stress factors used in B31 piping analysis |
AutoPIPE Advanced includes all codes available in AutoPIPE Standard, as well as the following codes.
| CSA-Z662 | Canadian Standards Association, Oil and Gas Pipeline System |
| CSA-Z662 Offshore | Canadian Standards Association, Offshore Steel Pipelines |
| BS 806 | Design and Construction of Ferrous Piping Installations for and in Connection with Land Boilers |
| BS 7159 | Design and Construction of Glass Reinforced Plastics (GRP) Piping Systems for Individual Plants or Sites |
| SPC-2 | Swedish Piping Code, Method 2 |
| TBK5-6 | General Rules for Piping, The Norwegian Pressure Vessel Committee |
| STOOMWEZEN | Dutch Piping Rule D1101 of the Rules for Pressure Vessels |
| DNV Offshore | Det Norske Veritas, Rules for Submarine Pipelines |
MITI 501 3-1980 |
MITI 501 Class III Piping Code |
| KHK | KHK E 012 Piping Code, Seismic Level 1 or 2 (Seismic Level 2 requires a KHK 2 Add-On license) |
| RCC-M | French Piping Code for Power Industry |
| SNCT | French Piping Code for Process Industry |
| SNIP Russian 2.05.06-85 Oil & Gas | Russian SNIP piping code for oil and gas |
| ISO 14692 | Petroleum and Natural Gas Industries - Glass Reinforced Plastics (GRP) Piping |
| B31.4 Offshore | Offshore Liquid Piping Systems |
| B31.8 Offshore | Offshore Gas Transmission |
| B31.12 Hydrogen Industrial Piping | ASME B31.12 Hydrogen Pipelines (Section IP) |
| B31.12 Hydrogen Pipelines | ASME B31.12 Hydrogen Pipelines (Section PL) |
AutoPIPE Nuclear includes all codes available in AutoPIPE Standard and AutoPIPE Advanced, as well as the following codes.
| ASME NB Nuclear | Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection NC, Class 1 Components |
| ASME NC Nuclear | Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection NC, Class 2 Components |
| ASME ND Nuclear | Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection ND, Class 3 Components |
| ASME NCD Nuclear | Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection NCD, Class 2 and Class 3 Components |
| JSME PPC Nuclear | JSME S NC1: Rules on Design and Construction for Nuclear Power Plants, Class 2 Piping |
| How to Activate AutoPIPE® |
Subscription Entitlement Service is Bentley's licensing model, providing enhanced security and optimized value for your Bentley Subscriptions. It is integrated with Bentley's Identity Management System (IMS) to allow near real-time reporting of usage, improved alert messaging to users and increased administrative capabilities to license administrators in your organization. It will not only give you more options to monitor and manage usage but also provide new, advanced licensing features that will enhance digital workflows.
With Subscription Entitlement Service, all users must be registered with Bentley's Identity Management System (IMS) and sign in to the CONNECTION Client to access Bentley applications. Product activation will now occur through user sign-in to the CONNECTION Client with a valid IMS ID associated with their account. User sign-in will replace traditional activation keys, offering enhanced security as administrators will be able to control which users have access to Bentley software. License entitlements are granted and maintained through Subscription Entitlement Service's Entitlement Management Service. By signing into the CONNECTION Client users can also find their organization's projects, download software updates, receive relevant notifications, and track their usage.
Subscription Entitlement Service features the new license alerts notifications that can be set by an organization's license administrators to let the users know when they reach a set usage threshold. These notifications will alert the users that if they continue to use the product, a term license may be issued. The user in such a situation has the choice to quit the application before a license is used or acknowledge that a term license may be generated and proceed with starting the application, based on what settings the administrator chooses.
| Error History |
The following outline identifies all major errors fixed in Release of AutoPIPE v23.0.1.
| Copyright |
Bentley, the "B" logo, AutoPIPE, MicroStation, ProjectWise, SELECT, and MDL are either registered or unregistered trademarks or service marks of Bentley Systems, Incorporated, or one of its direct or indirect wholly-owned subsidiaries. Other brands and product names are trademarks of their respective owners.
© 2025, Bentley Systems, Incorporated. All Rights Reserved.
Including software, file formats, and audiovisual displays; may only be used pursuant to applicable software license agreement; contains confidential and proprietary information of Bentley Systems, Incorporated and/or third parties which is protected by copyright and trade secret law and may not be provided or otherwise made available without proper authorization.
Complete copyright information can be found in the product by choosing Help > About.
For reference, a copy of the End User License Agreement named "EULA.pdf" is included in the product installation folder.
Corporate Headquarters Bentley Systems, Incorporated |
Bentley EMEA Bentley Systems International Limited |
Bentley Asia Bentley Systems (Beijing) Co., Ltd. |
| Online Information |
requires access to the Internet
How do I download, install, and license AutoPIPE?
