Before You Start
GeoStudio Minimum System Requirements
- Internet Connection
- For the Subscription Entitlement Service (SES) Licensing used in all GeoStudio software, an internet connection is required.
- For 2D analyses:
- Operating System: Windows 11
- Processor: Intel Pentium 4 or better, or AMD Opteron or Athlon 64 or better (GeoStudio is optimized for multi-core Intel processors.)
- System Memory: 4GB RAM
- Storage: 64 GB hard disk space
- Display: 1024x768 screen resolution
- Graphics Requirements: NVIDIA® GT 300, ATI® Radeon® HD 4000 Series, Intel® HD Graphics 3000/2000.
- For 3D analyses:
- Processor: Intel i5 or better (GeoStudio is optimized for multi-core Intel processors.)
- System Memory: 8GB RAM
- Storage: 256 GB hard disk space
- Display: Full HD
- Graphics Requirements: 2GB VRAM / DirectX 10+ support, e.g. NVIDIA GeForce, AMD Radeon
Note: as GeoStudio is updated, the requirements on this page will be updated as necessary.
GeoStudio Recommended System Requirements
- For 2D analyses:
- Operating System: Windows 11 x64
- Processor: Intel® i5, i7, i9, AMD Ryzen
- System Memory: 16GB RAM
- Storage: 500GB
- Display: Full HD
- For 3D analyses:
- Processor: Intel® i7, i9, AMD Ryzen
- System Memory: 16GB RAM or more
- Storage: 500GB
- Display: Full HD or higher
- Graphics Requirements: NVIDIA GTX 16 series, NVIDIA RTX 20 series with 4GB memory or better
System Considerations for Optimal Performance
When purchasing or upgrading a PC or considering where to install GeoStudio, consider the following:
- Multi-core processor:
- SLOPE/W, the GeoStudio “flow products” (SEEP/W, TEMP/W, AIR/W, and CTRAN/W), and SIGMA/W are formulated to take advantage of every thread available.
- All else being equal, more cores (or threads) will equal faster solve times.
- It isn’t quite linear: solve time will not be halved by doubling the number of threads, but this is where the most improvement can be seen.
- It's generally worthwhile having at least 4-6 cores.
- Clock speed:
- Doubling the clock speed will result in halving the solve time.
- Hard drive:
- The GeoStudio solvers write a lot of data to disk while solving, and a lot of data is read from disk while viewing results.
- Fast disk access will result in:
- Faster solve times.
- Optimal response time when viewing of results:
- Contouring.
- Graphing.
- Viewing results across multiple time steps or analyses.
- A Solid State drive (SSD) will provide the best performance.
- Working across a network drive may negatively impact performance if the network connection speed is slow.
- RAM:
- Memory usage is very project-dependent and application-dependent.
- In general a typical 2D problem can be solved with 2-3 GB of RAM.
A 2D problem using 4 GB of RAM and upwards is not abnormal but would be considered large.
