This guide contains links to documentation on functions that can be used in OpenGround expressions.
Text manipulation, logical, math, and other general purposes functions. Unless otherwise noted, many of these expressions can be used across the various Expression Engines.
Functions that can be used to perform Aggregation in Template Expressions.
Functions that can be used to perform Aggregation in Model Calculation Expressions.
Functions that can only be used within Import/Export Mappings.
Mathematical and logical operators.
Functions that can only be used in certain Template expressions to return information about the report being generated.
Functions that apply to Quick Section Template expressions.
