Bentley AutoPIPE CONNECT QAR v23.00.01
Acceptance Test Set Readme
Version
Compatible with Bentley AutoPIPE CONNECT QAR v23 (Version 23.00.01.367)
Operating Systems
Microsoft Windows (see System Requirements for specific details)
Language
English
Date
August 24, 2020
Software Verification Test Systems
The Bentley AutoPIPE Acceptance Test Set (ATS) provides the user with a recommended procedure for validating the integrity of the installed AutoPIPE 23.00.01.367 program.
Prior to any commercial or Quality Assured release, the accuracy of the AutoPIPE program is verified by the execution of Alpha Tests. These Alpha Tests consist of a matrix of test systems designed to capture key feature attributes related to numeric and functional processing. Each set of test outputs is compared to a prepared set of expected results (i.e. hand calculations, some other well-established computer program, etc.), and evaluated for acceptance.
The Acceptance Test Set includes input files and full documentation covering a sampling of test systems and results documented from the Alpha Tests.
§ System Requirements
§ Product Directory Structure
§ Installation Help
§ Documentation
§ QA Reporting Notices
AutoPIPE
A fully authorized copy of AutoPIPE Version 12.04.00.14 must be installed on your system prior to installing the ATS system files.
Processor
Intel Pentium IV or higher
Operating Systems
§ Microsoft Windows 10 x64 Professional or higher § Microsoft Windows 11 x64 Professional or higher
Memory
4 GB recommended. More memory almost always improves performance, particularly when working with larger models.
Hard Disk
1 GB free disk space (not including Restore Point space requirements).
Input Device
Any industry-standard input device supported by Microsoft Windows.
Output Device
Any industry-standard output device supported by Microsoft Windows.
PDF Reader
Adobe® Acrobat Reader 7.0 or greater.
1. Locate and run the QAAcceptanceTestSetx64.msi to initiate the installation process. The setup program will guide you step-by-step to install the contents to the hard disk.
2. The default destination directory is "C:\Bentley\AutoPIPE 2023 QAR ATS".
3. The input files will be placed in the specified destination and the previously verified output files(benchmark) will be placed in a directory named “OUT” located in the destination directory.
4. Once all the files have been installed, the setup program will display the final dialog. An icon will be added to the program group allowing you to review this file at a later time.
5. Select “Finish” to complete the installation.
Error reports are available with client participation in the "QA & Reporting" services. Monthly error reports, open error summary lists, and details of errors corrected through respective software releases are posted as PDF or spreadsheet documents to a private QA&R Community under the Bentley Communities website: http://communities.bentley.com/.
Note: The old error reports page will cease to exist under http://selectservices.bentley.com/en-US/.
Question 1: How do I get access to the QA&R error reports?
Answer: QA&R error reports are available on a private QA&R Community under the Bentley Communities website: http://communities.bentley.com/. QA&R subscription is required to access the QA&R error reports.
Question 2: My organization has QA&R subscription. Why I cannot access the QA&R error reports?
Answer: Access to QA&R error reports is available to the person(s) nominated to receive monthly error report notifications, by respective organizations, as listed on form 6-1-2: Contact Personnel for "QA & Reporting" Subscriptions.
If you have any questions as to the acceptability of the contents of the Comparison Log file for QA validation purpose, please contact Technical Support.
Bentley, the "B" logo, AutoPIPE, MicroStation, ProjectWise, SELECT, and MDL are either registered or unregistered trademarks or service marks of Bentley Systems, Incorporated, or one of its direct or indirect wholly-owned subsidiaries. Other brands and product names are trademarks of their respective owners.
© 2023, Bentley Systems, Incorporated. All Rights Reserved.
Including software, file formats, and audiovisual displays; may only be used pursuant to applicable software license agreement; contains confidential and proprietary information of Bentley Systems, Incorporated and/or third parties which is protected by copyright and trade secret law and may not be provided or otherwise made available without proper authorization.
Complete copyright information can be found in the product by choosing Help > About.
For reference, a copy of the End User License Agreement named "EULA.pdf" is included in the "C:\Bentley\AutoPIPE 2023 QAR ATS" (default location) folder of the product installation.
Corporate HeadquartersBentley Systems, Incorporated |
Bentley EMEABentley Systems International Limited |
Bentley AsiaBentley Systems (Beijing) Co., Ltd. |
