Join the Bentley Developer Network
Your organization must be a member of the BDN to use the OpenGround API. The BDN is free to join for existing Bentley users for internal (non-commercial) development purposes. Options are also available for those that wish to develop commercial software that integrates with OpenGround.
To join the Bentley Developer Network (BDN), use the Contact Us link here.
The BDN team will then contact you with instructions to proceed with the application process. One of your organization's internal Bentley Administrators will need to complete the application process.
We recommend notifying your contact within the OpenGround team when your BDN application has been submitted and approved so they can proceed with the onboarding process.
