| Version(s): | ALL |
| Area: | Calculations |
| Date Logged & Current Version |
January 2025 45.00.03.001 |
The following message appears when using AutoPIPE Vessel,
587 - NOZZLE N1: nozzle neck thickness < required thickness per UG-45.
why and how to avoid?
This error message appears when the nozzle neck thickness is less than the required thickness according to UG-45.
In this case, the required nozzle neck thickness as per UG-45 is 0.14 inches (without mill tolerance of 12.5%). After considering the mill tolerance of 12.5%, the required nozzle neck thickness as per UG-45 is 0.16 inches, which is higher than the nominal nozzle neck thickness of 0.154 inches.
This error message can be avoided by using a higher nozzle neck thickness (greater than 0.16 inches).
