This example is based on Primer 72 and also similar to A1. MOMENT-HINGE EXAMPLE (WITH ADINA USER INTERFACE) step-by-step process.
However, subtle modifications have been applied. The geometry now includes short lines which allow to place the Link Elements (Moment Hinges) in an inner position within beams.
The tutorial is presented in three videos:
Part I - Frame Structure Modeling
Part II - Including Link Elements (Moment Hinges)
Part III - Obtaining Results
See Also:
New Link Elements in ADINA 2024: How to Use
