Telerik Security Vulnerability with CONNECTION Client
We do not use RichTextBox, so there is no risk for CONNECTION client/Licensing using the library since we do not use the part that has a problem.
"If a project is not using the RichTextBox, the application is unaffected by this issue."
Here is the official Telerik documentation:
https://docs.telerik.com/devtools/wpf/knowledge-base/kb-security-unsafe-deserialization-cve-2024-10012
CONNECTION client does not allow the following Telerik components:
The future release of the CONNECTION client/License service will remove the reference to Telerik
CONNECTION Client Release Notes
