| Version(s): | ALL |
| Area: | Error Message |
| Date Logged & Current Version |
Jan 2025 45.00.03.001 |
The following message appears in AutoPIPE Vessel, how to avoid it?
20 EXTERNAL PRESSURE: stiffener (No. xxx) INSUFFICIENT or NOT CONSIDERED
As mentioned by the error text, the stiffener is insufficient. Open the complete report and select the hyperlink text to go to the report section in question.
Example:
Modify the stiffener as needed until the message is no longer shown.
