| Application | PLAXIS 2D |
| Version | PLAXIS 2D 2024.2 |
| Date created | 30 December 2024 |
| Date modified | 30 December 2024 |
| Original author | Felipe Fonseca - Technical Writer Geotechnical Analysis |
With the release of PLAXIS 2024.2 a new capability is added to consider the asymmetric interaction between bending moments and axial forces in elastoplastic plates and embedded beams materials.
1- Symmetric moment-axial force interaction (already available in previous versions of PLAXIS 2D)
In symmetric combinations of bending moments (M) and axial forces (N), failure occurs under identical states of compressive (N<0) and tensile forces (N>0), this represented, in PLAXIS 2D as |Np,1,tens| = |Np,1,comp|. Therefore:
Figure 1 displays the ultimate combinations of symmetric Mp-Np interactions for which plasticity will occur. Notice that force combinations inside the diamond correspond to purely elastic deformations.
2- Asymmetric bending moment-axial force interaction (Available from PLAXIS 2D 2024.2)
In asymmetric bending moments and axial force interactions (as it can be for materials such as concrete) failure might be reached under different compressive and tensile states, where |Np,1,tens|≠ |Np,1,comp| . In this circumstance. Therefore, the maximum bending moment allowed is no longer reached when axial forces are zero. Instead, the maximum bending capacity is found at a certain axial force N1,|Mp|.In asymmetric conditions, elastic deformations occur when the combination of forces fall inside the region described in the expression below and Figure 2:
In the PLAXIS 2D interface, the material strength parameters of elastoplastic plates under non-isotropic conditions can be visualized as in Figure 3:
Parameter |
Description |
Units |
Maximum bending moment (without any acting normal force) of the plate material. |
[KNm/m] |
Maximum tensile axial force along plate's first local axis (without any acting bending moment) of the plate material. |
[KN/m] |
Maximum tensile axial force along plate's second local axis of the plate material. Note that the axial force in the second local axis direction does not take part in the interaction diagram shown in figure 3. |
[KN/m] |
Maximum compressive axial force along plate's first local axis (without any acting bending moment) of the plate material. |
[KN/m] |
Maximum compressive axial force along plate's second local axis of the plate material. Note that the axial force in the second local axis direction does not take part in the interaction diagram. |
[KN/m] |
Axial force N1 for which the maximum bending moment |Mp | can be obtained. The value can be either positive (tension) or negative (compression). |
[KN/m] |
The moment-axial force interaction for elastoplastic embedded beams follows similar principles to those of plates in terms of their material strength parameters. However, since embedded beams are one-dimensional structural elements with only a single main axis, isotropy is not applicable. The strength parameters for these structural required by PLAXIS 2D are displayed below:
Parameter |
Description |
Units |
Maximum bending moment (without any acting normal force) of the embedded beam material. |
[KNm/m] |
Maximum tensile axial force (without any acting bending moment) of the embedded beam material. |
[KN/m] |
Maximum compressive axial force (without any acting bending moment) of the embedded beam material. |
[KN/m] |
Axial force N for which the maximum bending moment |Mp| can be obtained. The value can be either positive (tension) or negative (compression). |
[KN/m] |
