| Version(s): | All | ||
| Area: | Error message | ||
Problem:
The following is displayed when trying to open a model in AutoPIPE:
Error
E512-67: The model cannot be saved as at the new directory
as it cannot be copied to the new model directory
Possible Reasons could be:
Network Connection Failure
OK
How to resolve the issue?
Use the following instructions here to run a WinDBG application to generate a Log file. Next search that application for "Library not registered"
If no, "Library not registered" does not occur in the log file, create a new technical support case and send the log file for review.
If yes, for Suggest one or more of the following solutions below (referenced from Microsoft):
Solution 1. Component Services.
1. Press the Windows key and type in Component Services and press enter.
2. On the left side panel, navigate to Component Services > Computers > My Computer.
3. Click on DCOM Config and click on "Yes". Wait until all DCOM application reloads.
4. Close & Restart your computer, and when it boots up, check to see whether or not the problem has been resolved.
Solution 2. Run SFC & DISM in an ADMINISTRATOR mode.
1. Press the Windows key, type in CMD right-click and click on "Run as an administrator".
2. Copy-paste: DISM /Online /Cleanup-Image /RestoreHealth
3. Press Enter. Wait until completes.
4. Copy-paste: sfc /scannow
5. Press enter. Wait until completes.
6. Restart your computer, and when it boots up, check to see whether or not the problem has been resolved.
Solution 3. Get help with Windows activation errors.
You may try following these steps. Check this article for detailed instructions. It is written by Windows Support, so it is safe.
https://support.microsoft.com/en-ph/help/10738/...
