Modelling Techniques (Add or Modify)
A. General
B. Pressure Vessel
    1. Model vessel on vessel (small vertical vessel mounted on nozzle of horizontal vessel)
    2. Rectangular shells and nozzles
    3. Model Oblong, Elliptical, Obround openings
C. Heat Exchanger
    1.  Limitation, cannot model double tubesheeet, please add your vote to IDEA here.
    2. Modelling of nozzle mounted on Tubesheets
D. Tanks
E. Supports
    1. Model a leg support flush-mounted on the shell
    2.
Support Solutions and FAQ's
System Messages (ex. Error, Warning, etc..)
Bentley AutoPIPE Vessel
