Use the Dashboard to construct and curate a collection of widgets, alarms, charts, images, data entry elements, and other information displays like interactive maps or the current weather conditions at a specific location.
1. Click the Dashboards icon on the Main Menu.
2. The Dashboards Tree lists the dashboards that are available to you. Click on the dashboard that you wish to display.
Note: To create a new dashboard or add a dashboard to the list, use the Dashboard Manager. To remove a dashboard from the list, follow the instructions in the Edit a Dashboard topic.
