Roadway Technician
OpenRoads from conception through construction
Are you a  Road and Highway Technician responsible for Producing, Annotating, Managing and Publishing Plansets and other production deliverables?
This page is designed to show you how to quickly get creating.
Training Courses
OpenRoads Designer - Drawing Production Learning Path: this Learning Path will teach you everything you need to know to understand the Bentley Civil data and create plan profile and cross section sheets.  Note that this path assumes you know the fundamentals of how OpenRoads/OpenSite works.  Refer to the initial learning paths for that instruction.
What's New in Drawing Production:  Drawing Production Skills Adoption
OpenRoads Designer Overview
Product Overview: Bentley OpenRoads Designer
Subscribe and follow the Bentley OpenRoads YouTube channel for even more useful information, tips, tricks and tutorials here: Bentley OpenRoads YouTube
View this Tech Talk to learn how OpenRoads allows you to model proposed drainage networks while using comprehensive analysis tools to design, review, and verify stormwater capacity. See the advantages of creating a 3D model of the drainage network Demonstrate the hydraulic analysis tools Understand the interaction between the model and the analysis tools Demonstrate the dynamic nature of the evaluation and edits to the network and flow capacity. Simply click on the image below to start.
Case Studies
CDM Smith Improves Dubai-Al Ain Road
See more User Projects at https://www.bentley.com/en/project-profiles
