</colgroup
| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | |
| Date Logged & Current Version |
Dec 2024 24.00.01.152 |
The following is displayed when opening a model or running a model consistency check in AutoPIPE:
E2143-12: Piping code specified requires AutoPIPE Nuclear
How to fix this issue?
The reason for this is because the model analysis use a Nuclear code and the current license used by the application is non-Nuclear.
Avoidance #1:
Change the license to AutoPIPE Nuclear configuration (File > License > Configuration).
Notes
1. The image above was taken from AutoPIPE 24.00.01.152. Your dialog may appear differently and may be under a different command structure, see AutoPIPE help for details to set License Edition.
2. Contact your company appointed Bentley On-site Admin asking them to check to be sure AutoPIPE Nuclear is on account, and to please provide you entitlements for AutoPIPE Nuclear licensing.
Avoidance #2:
Change the Piping code from Nuclear to Non-nuclear code on the General Model Options dialog (Tools > Model Options > General Options)
You will need to decide, which code to use. Select any besides ASME NB, NC, ND, NCD,
