Bentley Infrastructure Cloud makes it easy to connect people and data across the entire infrastructure lifecycle to create, curate, inform, manage, and leverage iTwins for superior infrastructure project delivery and asset performance workflows.
Accelerate collaboration
Easily access the right information to make better decisions using a suite of integrated, cloud-based products
Maximize productivity
Do more, faster with purpose-built digital workflows created for users across all phases of the project and asset lifecycles.
Exceed expectations
Design, build, operate, and maintain more resilient and sustainable infrastructure with evergreen digital twins.
Take advantage of digital twins and Bentley’s infrastructure schemas to leverage data across projects, maximize insights, learnings, and reuse from previous projects. With new tools to make the most of your data, Infrastructure Cloud makes it easy to innovate without disruption in the face of today’s complexities.
Entitlements
Bentley Infrastructure Cloud uses two different entitlements.
- Bentley Infrastructure Cloud Connect
- Bentley Infrastructure Cloud ProjectWise
- Connected data environment across projects and assets
- Improved collaboration for infrastructure teams and organizations
- Unified experience for design firms, construction firms and owner-operators
Features and Capabilities
- Manage Project and Assets
- Create/edit/Update/delete iTwins
- Invite/remove participants, Create/modify/assign Roles
- Manage Deliverables Management
- Content configuration
- Create/modify/delete connections and Office 365 settings
- Create/modify/delete Forms definitions
- Configure PDF Settings, Inspections and Cost codes
- Consumption of Information
- Model Viewer
- RFI, Daily logs, forms, and field collaboration with SYNCHRO Field App
- Reporting
- Dashboard, Insights, PowerBI
- Data Enrichment and Federation
- Enable map layer and create/modify/delete GIS cnnections
- View Reality Data
- Bentley Open Application connectors
- Third-party application connectors
- Collaborative Workflows
- Embodied carbon calculations for design, build and operations
- Create/edit/delete issues
- PDF Markup
- Create/modify/delete PDF management renditions
- Create/Issue/Respond transmittals and submittals
- Clash Management – View Clash results
- View and reuse components (Component Center)
- Integrated project delivery workflows including CAD integration services, enterprise rules-driven engineering WIP, engineering desktop and Digital iTwin Review
- ProjectWise Cloud (DI deployment) is the go - forward solution and a prerequisite for our users to benefit from the many recently announced enhancements, such as:
- AI- based search across data sources
- A newly designed Explorer desktop experience
- New and event-based renditioning service (ICS)
(All features of Bentley Infrastructure Cloud Connect, plus)
- Clash Management – Create/edit/run Clash Jobs and View Clash results
- Advanced civil tools
- Application integration, reference file management, managed workspaces (incl. PW Explorer)
- Visualization of planned schedules
- Extract and curate reusable components
[Note: This behavior may be different if users access a project from an External Organization.]
Please Refer to the following articles for more details:
