Every course you complete below from our LEARN Server is recorded to your online transcript.
Use it to track your professional growth over time, print Certificates of Completion, and self-report your learning efforts to maintain your credentials.
| Learning Path | Description of the course |
| QuickStart: Mechanical BIM Modeler Accreditation | During this session, you will learn how to create an HVAC model of a small commercial building using modeling tools for air handling units, ductwork, duct fittings, air terminals, and connections. In addition, you will generate drawing views from the BIM model. Once you have completed the BIM QuickStart Mechanical Live Bundle, you will have the opportunity to become a Bentley Accredited BIM Modeler by completing the required coursework and signed accreditation agreement. |
| Mechanical BIM Professional Track | In this session, you will learn how to use Bentley's BIM solution, OpenBuildings Designer, for professional project delivery. Courses on HVAC design including custom air-handling units, single-line duct modeling, 3D duct modeling, HVAC analysis and drawing and report generation are included. |
Parent topic: Mechanical Engineering Professionals
