Can parts of the output report containing materials not used in the model be removed?
Example:
The following output report indicates materials in red that are not currently used in the AutoPIPE Vessel model:
Question:
What is needed to fix this issue so that the "?" do not appear in this report.
Answer:
The "?" will be updated after the user defines the Safety Factors for those materials on the "Unablated Allowable Stress Computation" dialog, imaged below:
Question
Can these sections of the report with material not used in the model simply be removed.
Answer:
This is not a bug, it is just to remind the user that the design code does not specify values ​​for these categories and the user will need to enter the values ​​if non-ASME materials are used.
Avoidance, input the missing values:
Or remove the section from the Report:
