Learning Tips for Structural Modeling
Become a more productive and well-rounded OpenBuildings Designer Structural user through OpenBuildings 'Learning Tips'.
Cut Openings in Structural Members
Learn how to use the Cut Openings tool to cut openings in structural members in OpenBuilidngs Designer.
https://youtu.be/RiAggk1EF0U
https://youtu.be/Iow0RhUbp-o
Modify Height on Multiple Columns
Learn how to modify the height of multiple columns in OpenBuildings Designer using the Modify Properties tool.
Support Options for Framing Between
Learn how to get the structural framing aligned with the correct edge of the supporting structural member in OpenBuildings Designer.
https://youtu.be/XnVBzEq2_IY
OpenBuildings Designer Update 7 and forward features the next generation of structural elements by utilizing the Bentley ProStructures application shape catalogs.
https://youtu.be/reNBcWjqkfY
Custom Structural Shapes
In this video learn how to create a custom User Shape and add it to the Shape catalog.
Parent topic: Tips & Tricks for all Disciplines
