</colgroup
| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Warning |
| Date Logged & Current Version |
Dec 2024 24.00.01.152 |
The following is displayed when using AutoPIPE
Warning
W45-85: Gasket dimensions are not available for
the selected Gasket type for rating 1500
having a nominal pipe size of 304.800 mm
OK
Why and How to avoid it?
As the message states, there is no gasket information available in the Gasket Library file.
To completely understand this issue, perform the following:
Avoidance
The only avoidances are:
1. Post a new IDEA to AutoPIPE's idea page asking for the flange database to be updated with information on a particular flange. And wait for a future version of the application to be released with this update library.
or
2. Select settings on the Flange dialog so this warning message above does not appear.
or
3. Manually update the Flange database with your specific data. Save the file back to the installation folder. If using this option see warning message below
Remember, being a custom library file, Bentley cannot be held responsible for the inaccuracy of the new library content. It is your responsibility to verify the program is retrieving and using the data correctly.
