If you are are new to MicroStation but previously worked with AutoCAD, the following links will show you how to setup MicroStation to have the familiar look and feel as AutoCAD.
Using AutoCAD key-ins in MicroStation CONNECT Edition
Once you have setup MicroStation, check out the following Learning Path:
MicroStation for AutoCAD Users CONNECT Edition - Bentley Learn
These topics will cover:
In addition, you can then learn more about MicroStation with the basics to more advanced topics.
Top 10 New Capabilities of MicroStation CONNECT Edition
MicroStation CONNECT Edition 2D Basics
Tips & Tricks for MicroStation CONNECT Edition
