Error Number 675 - GEOMETRY (xxx): thickness = xx mm (>= xxx mm) ==> PWHT is required.
Question:
After performing strength calculation on a model, the following error message in AutoPIPE Vessel appears:
  675    GEOMETRY (xxx): thickness = xx mm (>= xxx mm) ==> PWHT is required.
Why and how to avoid it?
Answer:
Please open AutoPIPE Vessel help screen and search for PWHT:
Select the topic = Requested, and read the information provided.
As mentioned, even if the Requested options is not checked yes, the calculation is carried out and error message printed.
