How to Set the Active Bridge
Question
How to change the Active Bridge to another one?
Answer
As shown in the image below, when the same file has more than one bridge users should know how to change the Active Bridge to go back to a previously defined bridge.
1. Go to File \ Explorer
2. At the OpenBridge Model window expand the Bridge Model and then the Bridges tree menu, and check which Bridge is active.
 The Active Bridge name is highlighted in green, it has the ** symbol at their name side, and it appears in the Properties window.
3. Right-click over the inactive Bridge
4. Select Set Active Bridge
 The bridge name should now turn green as the current Active bridge name.
