This is the overview for the Project Settings dialog box, which can be populated by selecting Project > Project Settings in the Main Menu, by selecting the Project Settings button in the Toolbar, or when initiating a new SPIDAcalc project. Project Settings is the control center where project-level information can be added and updated. Users can open this dialog box at any time to update project information.
The Project Settings dialog box consists of six tabs:
There are two buttons found at the bottom of the Project Settings.
The General tab provides fields to enter project information and select a client file.
Within the Client Information section, users can see the active client file. Selecting the Change Client File button will open a dialog box with a dropdown from which the user can select a different client file.
Below the dropdown in the Change Client File dialog box is the client file comparison tool. Tabs indicate how many structures, assemblies, load and strength cases, or forms differ between the original client file and the new one. Selecting a tab will highlight the added, removed, or modified components found in the new client file. The comparison table can be exported into an Excel file.
From here, the user can select OK to proceed with updating the project based on the client file changes and mapping project components to the new client file or Cancel to exit.
The General Project Information section also provides several optional text fields for a user to complete. The data provided in this section can be delivered in a report and autofill other SPIDAcalc dialog box fields.
General location and address information added in the Address section will appear in reports. If the Update All Locations button is selected, the address will automatically appear in the Address section in the Location Properties Panel for all project locations. Otherwise, it will appear only in project locations created after the field entry was completed.
Anything added to the Comments section will appear in reports.
The Loading sub-tab provides users with the ability to add, remove, or modify load cases at the project level. The Loading tab is divided into two sections.
The Strength sub-tab provides users with the ability to add, remove, or modify a strength case at the project level. Strength cases are created in the Client Editor. Strength cases included in the client file will appear in the dropdown. When a strength case is applied, SPIDAcalc can evaluate the impact of damage and decay entered by users to determine the remaining strength and capacity of the pole.
The Clearance tab provides users with the ability to add or remove clearance cases at the project level. The Clearance tab is divided into two sections.
Design Layers can be defined in the client file. A design layer that has been added to an existing project can be modified by the user to change the Name or Type of that design layer. Users also have the ability to reorder the design layers by dragging and dropping them into a new order.
The Design Layers tab is also where terrain layers that have been added to the project can be applied. Terrain layers can be applied to all designs or a specific design layer.
Terrain layers can be built from an automated import via a service, or imported from a CSV file. The supported services include the USGS Elevation Point Query Service and Natural Resources Canada.
Multiple terrain layers can be built and applied separately to different design layers; this is to support changes to the terrain throughout the design process.
Project forms are created in the Client Editor. If a project form is included in the client file, it will appear under the Project Forms sub-tab in the dropdown menu, which is dynamic. If a project form was set to Include Form by Default, the form will be selected automatically. Project forms can be removed one at a time by using the Remove button or all at once using Remove All.
Project forms collect additional project information that can be displayed in reports.
Location forms are also created in the Client Editor. If a location form is included in the client file, it will appear under the Location Forms sub-tab in the dropdown menu, which is dynamic. If a location form was set to Include Form by Default, the form will be selected automatically. Location forms can be removed one at a time by using the Remove button or all at once using Remove All.
Location forms can be applied to each location at the project level to collect additional data for each individual pole. Data recorded in location forms can be displayed in reports.
