Reports
SPIDAcalc provides all users with access to six default reports that output formatted project information ranging from the most comprehensive to more narrowly focused. A custom report option is also available for users to select specific report sections and project parts as needed. Lastly, client reports can be created in the Client Editor. A client report contains predetermined report fields that can be made available to users via the client file.
ACCESSING REPORTS
Reporting options are displayed in an expanded list under the Tools menu. When Reports is selected, the following reports will appear:
REPORTING OPTIONS
The first three reporting options in the expanded menu are configured with specific report sections by default. Users can change the default settings by enabling or disabling any of the report section checkboxes. The Project Summary Report, Project Details Report, Project Design Comparison ReportProfile View Report, and Custom Report all generate in HTML or PDF format and can be saved to a specific folder. The Excel Report and Wire Tension Report generate and save as a .xlsx file.
Users can also select the project parts they wish to appear in any SPIDAcalc reports. When the Project Parts tab is selected, all leads, locations, and designs within the project are selected by default. To remove a lead, location, or design from a report output, uncheck the selection box.
REPORT OUTPUT
Below is a summary of the Report Sections included in the report selections.
The Wire Tension Report will only contain results if a load case has the "Maximum Wire Tension Check" enabled.
REPORT LOGO
At the top of any HTML or PDF report, a custom company logo can be displayed. Logos are added to reports via the client file. Users can upload a logo in the Client Editor by selecting Options Set Report Image.
RESOURCES
View media
https://communities.bentley.com/products/spida/m/files/275887
