Substructure – Pile Bent – Bending Moment Diagram
Document Information
Document Type: FAQ
Product(s): LEAP RCPier
Version(s): All
Original Author: Bentley Technical Support Group -VM
QUESTION: How to see both Positive and Negative moment in a Pile Bent, Bending Moment Diagram?
ANSWER:
The reason the program does not show the Positive moment at the center of the beam is because
there is no Node assigned between 2 piles.
When the user assigns additional check points between 2 piles then the program will show both the
Positive and negative moments in the Bending Moment diagram for Self-weight condition.
