The structures available in the Components Panel are determined by your client file. If the Client Editor module is included in your license, you can add, remove, or modify structures in your client file.
For more information on how to do so, check out our article on Client Editor: Working with the Structures Tab - Wiki - SPIDA - Bentley Communities or this past lunch and learn about adding new materials to your client file.
