Question:
When analyzing a model in AutoPIPE Vessel the following warning number was reported.
312 NOZZLE xx: the external projection may not be sufficient (minimum=223 mm).
Why and how to avoid it?
Answer:
AutoPIPE Vessel checks that the height of the nozzle is sufficient, for example to take into account the insulation, otherwise a warning message is generated. This height can be change by the user:
Example:
Avoidance:
Enter a value such that the nozzle is high enough to clear items like insulations and cladding.
