SPIDAcalc Release Notes
This article provides release information for the current SPIDAcalc product generation, including new features, enhancements, defect fixes, compatibility information, and known considerations.
Current release: SPIDAcalc 26.0.1 Release Notes.pdf
New to SPIDAcalc v26?
SPIDAcalc v26 introduced significant new capabilities, including Lead Analysis, expanded sided pole analysis, bulk load case editing, and additional SPIDAcalc and SPIDAsilk workflow improvements. These features remain available in v26.0.1 and later v26 releases.
What's New in SPIDAcalc v26
Lead Analysis
SPIDAcalc v26 introduces Lead Analysis, allowing the analysis of a pole to account for the behavior of neighboring structures rather than treating each location entirely in isolation.
When Lead Analysis is enabled, SPIDAcalc models connected neighboring poles as flexible structures extending several spans from the structure being analyzed. This allows load sharing and deflection from adjacent poles, connected spans, and span guys to influence the analysis of the current structure.
Lead Analysis can be enabled on a per-load-case basis from the load case settings in Detailed Analysis, Project Settings, and Design Settings. It applies to co-rotational load cases with Update Tensions Based on Displacement enabled and to structures connected by a wire or span guy. Isolated poles continue to behave as they did in previous versions
Neighboring structures included in a Lead Analysis group are also displayed in the 3D Graphic View and 3D Analysis Summary, providing visual context for the structures contributing to the analysis.
Sided Pole Analysis
Bending stress evaluation for sided poles has been expanded. SPIDAcalc now evaluates bending stress at multiple section corner points to identify the maximum stress rather than evaluating only a single reference location. Pole orientation is also tracked consistently throughout the analysis engine for sided pole shapes.
Analysis and Design Workflow Improvements
SPIDAcalc v26 includes several improvements intended to make larger project editing and analysis workflows more efficient:
  • Multiple locations can be selected for bulk load case updates, allowing load cases to be added to or removed from several designs simultaneously.
  • Multiple disconnected wires can now be reconnected together, and the single-wire Disconnect Wire control has been moved into Component Properties for consistency.
  • Periods and decimals can now be used in lead, location, and design labels.
  • The last selected wire end point in Profile View is remembered when moving between designs and locations.
Import, Export, and Project Improvements
  • Pole CSV exports now respect the selected UTM coordinate-system preference.
  • Project forms include a validated URL field for projects being uploaded or saved to SPIDAstudio.
  • Invalid UTM coordinates encountered while creating a project from CSV now generate a warning rather than being silently ignored.
SPIDAsilk Improvements
SPIDAsilk's wind-pressure methodology has been updated to provide an option aligned with SPIDAcalc's CSA Maximum Wind methodology, including calculating wind pressure at the actual wire attachment height using the 10-minute mean wind-speed formula.
SPIDAsilk also includes improved load-case configuration management. Separate Save and Save As operations allow custom load cases to be updated while protecting default load cases from being overwritten. Weather Case configuration saving has also been improved.
SPIDAcalc v26 Release History
SPIDAcalc v26.0.1
Released: November 2026
SPIDAcalc v26.0.1 is a maintenance release focused on analysis correctness, file-version compatibility, Client Editor functionality, reporting, dependency updates, and security-related maintenance.
Analysis
  • Corrected an issue where the cubic and quartic terms of a conductor's stress-strain or creep polynomial could be dropped when shifting the curve from its reference temperature to the analysis temperature.
  • Because of this correction, re-analyzing existing projects may produce slightly different tensions, sags, and pole loads, particularly for AAC and copper conductors under cold/heavy or hot conditions. No changes to project or client files are required.
  • Corrected the base cross-sectional area used by the analysis engine for round hollow wood poles. This issue is unlikely to affect typical real-world projects.
File Conversion and Compatibility
  • Resolved an issue where analyzed projects saved to an older file version from v25 or v26 could not subsequently be reopened in v25 or v26. Analysis-result version information is now updated during conversion so down-converted projects can be converted forward and reopened successfully.
  • Projects saved from v25.0.x or v26 to a version earlier than v25.0 can now be opened in that older version. Rectangle and polygon pole shape multipliers that older versions do not recognize are removed during down-conversion.
  • Resolved a potential conversion error affecting files containing insulator types from older schema versions.
Client Editor
  • Resolved an issue preventing PLS pole data files from being downloaded in the Client Editor. Users who depend on this workflow should upgrade to v26.0.1 or later.
Reports
  • The Project Detail report now correctly displays Location where it previously displayed Lead.
Security and General Updates
  • Updated software dependencies where feasible and addressed various known security vulnerabilities.
  • Additional minor defects and dependencies were also updated.
Download: SPIDAcalc 26.0.1 Release Notes.pdf
SPIDAcalc v26.0
Released: September 2026
SPIDAcalc v26.0 is the major feature release for the v26 product generation. It introduced Lead Analysis, expanded sided-pole analysis, SPIDAsilk analysis improvements, workflow enhancements, and numerous defect fixes.
Features and Enhancements
Major additions include:
  • Lead Analysis for modeling the effects of neighboring connected structures.
  • Expanded sided pole stress evaluation at multiple section corner points.
  • Neighboring Lead Analysis structures displayed in the 3D Graphic View and 3D Analysis Summary.
  • Bulk load case editing across multiple selected designs.
  • Improvements to wire disconnect/reconnect workflows.
  • UTM-aware Pole CSV export.
  • Improved project form and CSV validation.
  • SPIDAsilk wind-pressure and Weather Case improvements.
  • Dependency and security updates.
Analysis Fixes
  • Resolved cases where primary wires or support guys on certain framing assemblies could cross without generating the expected analysis warning after the assembly was changed.
Reports
Resolved several report-generation issues, including:
  • Missing images in generated reports.
  • Failure of the Project Design Comparison Report to generate.
  • Report failures where analyzed load-case components did not contain the pole.
  • Project Detail report failures involving wire-mounted equipment.
Client Editor
The v26 release also improved several Client Editor workflows:
  • Improved handling when an equipment type referenced by a project has been removed from the client file.
  • Corrected property-field updates when changing equipment from Riser to Wire Mounted.
  • Corrected client-file structure exports when structure names contain parentheses.
  • Resolved generation of invalid v7.2 exchange files.
  • Added custom equipment types under Clearance Groups > Equipment.
Project Forms
  • Resolved crashes and exceptions associated with tables and radio buttons in project forms.
  • Corrected saving of default New Project Settings form values.
  • Prevented blank and duplicate table entries from being added to applicable form fields.
Graphic, Map, and 3D Views
Updates included corrections for project and map previews, Map View and station loading, damage rendering in 3D, tablet interaction, map-ruler display, 3D Analysis Summary updating, and radar-chart display.
General Reliability and Usability
SPIDAcalc v26 included improvements to autosave and project recovery, project opening, progress reporting, midspan pole placement, project-tree editing, clearance-case entry, weather-configuration persistence, application launch, authentication, service connectivity, and SPIDAsilk startup.
Download: SPIDAcalc v26.0 Release Notes.pdf
Compatibility and Upgrade Considerations
SPIDAcalc client and project files created in v26 may not be compatible with older versions of SPIDAcalc.
When upgrading:
  • Opening a client or project file created in an earlier version may take longer the first time because SPIDAcalc converts the file to the current format.
  • Importing designs from earlier project formats may similarly require additional conversion time.
  • Converted client files should be reviewed to ensure settings and values appear as expected. New Client Editor functionality should also be reviewed and implemented according to your organization's practices.
Release Notes and Supporting Documentation from Earlier Releases
SPIDAcalc v25.0.3 Release Notes.pdf
SPIDAcalc v25.0 Release Notes.pdf
SPIDAcalc v24.1.2 Release Notes.pdf
SPIDAcalc v24.1.1 Release Notes.pdf
SPIDAcalc v24.1 Release Notes.pdf
SPIDAcalc v2024 Release Notes.pdf
SPIDAcalc v8.0.1 Release Notes.pdf
SPIDAcalc v8.0 Release Notes.pdf / SPIDAcalc v8.0 New Features and Functionality.pdf
SPIDAcalc - v7.3.2 Golden Release Notes.pdf
SPIDAcalc - v7.3.1 Golden Release Notes.pdf / SPIDAcalc v7.3 New Features and Functionality.pdf
