Warning Number 126 CHECKING ONLY (NO DESIGN): check warning message in calculation note.
Question:
When analyzing a model in AutoPIPE Vessel the following warning number was reported.
Why and how to avoid it?
Answer:
#1:
This message appears when the user select the option "Checked Design" to remind them that there is no design only a checking of the input data which generally generates issues highlighted in red in the report. This is more of an informational message than a warning.
Avoidance:
Choose Optimized Design radio button.
Otherwise, if here are no other issues with the model, the warning message will always remain.
#2:
If the model has Ladders and platform, confirm all of the data needed to define the ladders and platforms are provided.
Example:
What is missing here?
Answer: The angle, open AutoPIPE Vessel help to determine what values can be used here.
Hint: if model has a single line element representing the platform, this is incorrect. Open the platform element and enter an acceptable value for platform settings.
