Activating a product using the Product Activation Wizard
The Product Activation Wizard is designed to step users through the product activation process. After a product is installed, you must obtain a license and then activate that license. Obtaining the license alone is not enough to complete the process. This wizard eliminates the confusion and makes it clear that obtaining a license and activating a product are two essential steps.
The Product Activation Wizard opens automatically (unless the "Activate product using Bentley License Tool" check box is turned off) at the end of the product installation process. See the AutoPIPE Vessel Quick Start Guide for more information on installing AutoPIPE Vessel.
The first screen of the Product Activation Wizard offers four product activation options:
The wizard steps you through the activation process based on the options selected.
SELECT subscribers with a deployed (local) SELECT Server
If you are activating against a local SELECT Server, you must provide the proper Server Name and Activation Key. The Server Name and Activation Key, along with any proxy configuration information, can be obtained from your Site Administrator.
- Enter the name of the server in the Server Name field.
- Enter the site activation key in the Site Activation Key field.
- If you are using HTTPS, enable the HTTPS (SSL) check box.
- If you are using a Proxy server to connect to the hosted SELECT Server, click the Proxy button and fill in the Proxy Server information then click OK.
- Click Test Connection to verify the connection to the SELECT Server.
- Click Next. The Wizard Selections dialog box displays the information provided on the previous dialog boxes.
- Review the information and click Finish to activate the product.
SELECT subscribers activating against a hosted (Bentley) SELECT Server
If you are activating against a hosted (Bentley) SELECT Server, the Server Name is pre-populated but you must provide the proper Activation Key provided by the Bentley Sales Support Center.
NON-SELECT user
If you are not a Bentley SELECT subscriber and you are activating AutoPIPE Vessel, you are presented with three options:
- I have a license file ready to import
- I have an activation key
- I do not have any license information
- Enter the path to your license file (or Browse to the location of your license file) in the License File field.
- Click Next. The Check out license now? page displays.
- Enter your Email address in the Email Address field.
- Select the product to be activated (if not pre-populated) it the Product Name field.
- Enter the product version number (if not pre-populated) in the Product Version field.
- The product will run in evaluation mode.
- Click Go To Bentley.com to request activation information.
Evaluation Only - No license information
TRADEMARK NOTICE
Bentley, the "B" logo, AutoPIPE, MicroStation, ProjectWise, SELECT, and MDL are either registered or unregistered trademarks or service marks of Bentley Systems, Incorporated, or one of its direct or indirect wholly-owned subsidiaries. Other brands and product names are trademarks of their respective owners.
COPYRIGHT NOTICE
© 2016, Bentley Systems, Incorporated. All Rights Reserved.
Including software, file formats, and audiovisual displays; may only be used pursuant to applicable software license agreement; contains confidential and proprietary information of Bentley Systems, Incorporated and/or third parties which is protected by copyright and trade secret law and may not be provided or otherwise made available without proper authorization.
Complete copyright information can be found in the product by choosing Help > About.
For reference, a copy of the End User License Agreement named "Eula_en.pdf" is included in the "AutoPIPE Vessel" folder of the product installation. By default, this location is "C:\Program Files\Bentley\Engineering\AutoPIPE Vessel."
Corporate Headquarters
Bentley Systems, Incorporated 685 Stockton Drive Exton, PA 19341-0678 USA Phone: (1) 610 458-5000 FAX: (1) 610 458-1060 WWW: http://www.bentley.com/
International Headquarters
Bentley Systems Europe B.V. Wegalaan 2 2132 JC Hoofddorp THE NETHERLANDS Phone: (31) 23 556 0560 FAX: (31) 23 556 0565 WWW: http://www.bentley.com/nl-NL/
Asia Headquarters
Bentley Engineering Software Systems Unit 1402-06, Tower 1 China Central Place, Beijing 100022 CHINA Phone: (86) 10 5929 7000 FAX: (86) 10 5929 7001 WWW: http://www.bentley.com/zh-CN/
