| Version(s): | ALL |
| Area: | Calculations |
| Date Logged & Current Version  |
November 2024 45.00.03.001  |
The following message appears when using AutoPIPE Vessel,
319 HEAD: knuckle radius (1.2 in) not covered by code §UG-32 (j) (diameter=20 in , thickness=0.5 in).
why and how to avoid?
We face this error message when the dimensional criteria of Torispherical head are out of the scope of code requirements.
See below code reference, ASME Section VIII Div. 1, UG-32 (i),
As per the code, There are following three criteria for Torispherical Head,
Refer Below Example,
In this case,
knuckle radius = 1.2 in
Diameter = 20 in
Crown Radius = 20 in
Knuckle Thickness = 0.5 in
In above case, Criteria number 3 is not met., inside knuckle radius is not less than 3 times the head thickness.
To avoid the error you can change the knuckle radius or head thickness.
