Resolved Issues
The following issues have been corrected and/or added to the OpenCities Map 2024. Compare the reference number from your service request below to determine whether a given issue has been resolved in this release.
Version 24.00.01.75
Reference |
Summary Description |
Keywords |
751297 |
Please add OAuth2 Security authentication to the ArcGIS connections. |
Database |
752894 |
Update DGNLIBs text style fonts. |
Install |
755594 |
Ability to remove Database Connection from GSA. |
GSA |
903102 |
Inferred text element to feature causing issue in Data Browser. |
Inference Rules |
1000126 |
Geo_example provided schema updates. |
XFM |
1014028 |
Change contrast/brightness on reprojected Raster. |
Raster |
1060095 |
Add Single Sign-on (SSO) Connection to ArcGIS Connections. |
Database |
1075173 |
Stop delivering FME Objects assembly. |
Import - Export |
1104065 |
Reference Activate-Deactivate. |
Reference |
1167284 |
Using Meters units on Grids. |
Grids & Graticules |
1197389 |
Decode XML definitions from UTF8 on Geodatabase. |
Database |
1265084 |
Update of "Foreign List Lookup Watcher" option in GSA. |
GSA |
1314358 |
Point layers in PostGIS with imperial DGN. |
Database |
1368882 |
Flood Advanced placement mode. |
API / SDK |
1378821 |
Save As XFM version conversion. |
XFM |
1385166 |
The XFT/XFM VBA API is different than V8i. |
API / SDK |
1387772 |
Topology tool Connect Linear with spatial data. |
Database |
1389303 |
MapUltimate for Finland - Kiinteisto3D_Collection area value. |
XFM |
1399689 |
PostGIS CurvePolygon feature with arcs and ellipses. |
Database |
1423318 |
Named Boundaries Placement. |
Manipulation |
1423902 |
MapUltimate for Finland - Convert to Feature tool. |
XFM |
1428494 |
ArcGIS Rest polygon and complex chain. |
Database |
1439902 |
MapUltimate for Finland - Criteria to annotation offset symbology settings. |
GSA |
1442914 |
MapUltimate for Finland - KTJ Export output file update. |
Import - Export |
1451651 |
WFSX query by View and Where Clause. |
Database |
1451672 |
WFS query 1000 features limitation. |
Database |
1454843 |
Remove eB from Map. |
Import - Export |
1455842 |
MapUltimate for Finland - GISref raster attachments. |
Raster |
1458765 |
[WFS] Query Features and Clear Features from the same specific area. |
Database |
1468166 |
Flood method updated. |
XFM |
1471404 |
WMS Service Manager > Add New Service URL updates. |
Database |
1471406 |
Query polygons with the geographic coordinate system defined by the URL. |
Database |
1503791 |
MicroStation Display Rule key-ins in Map PowerView. |
Manipulation |
1532414 |
Print Preparation edit legend display. |
Printing |
1547441 |
MapUltimate for Finland - Cell sub-feature annotation offset. |
XFM |
