Question:
What exactly does this Warning message mean:
Example:
663 MATERIALS : a temperature (-15 °C) is less than the minimum usage temperature (-6.7 °C) of SA387GR22CL2 ASME II.
Answer:
Generate a complete output report of the calculations and search for the reported value (ex. -15 °C). Review each occurrence of the value looking for relevant information.
Example:
Design MDMT
Next, go back to the model to confirm the setting.
Example:
Finally confirm the library data on this material selection.
Note: Temp Usage Min = 20 Units system = US, Temp = 20°F or -6.7°C
Conclusion:
This notification serves to inform the user that the temperature specified in the model (ex. -15°C ) surpasses the limits of the chosen material (ex. 20°F or -6.7°C ). To eliminate this warning, consider the following options:
1. Select a different material that meets the requirements of your design.
2. Revise the material library with suitable values derived from testing conducted by a credible source.
