Q1. What default value does Autopipe use for behavior factor “q” in the case of EN 1998-1:2004?
- Answer:
- AutoPIPE Vessel uses:
Q2. In comparing the result from Autopipe with our analytical result, is there an option in Autopipe to see the spectrum of the elastic response generated?
- Answer:
- The spectrum is printed out in the report
