Q. Why is the nozzle's Di (inside Diameter) value shown on the dialog different than reported?
Example:
AutoPIPE Vessel's input dialog
Reported value
Answer:
Don't confuse the internal diameter of the Nozzle with the largest actual diameter of the opening.
