| Product(s): | WaterGEMS, WaterCAD, HAMMER, StormCAD, SewerCAD, SewerGEMS, CivilStorm |
| Version(s): | 24.00.01.XX (of MicroStation) |
When using an OpenFlows product integrated with MicroStation 2024 (specifically update 1, 24.00.01.XX), a crash occurs when trying to load a new or existing hydraulic model- "MicroStation has stopped working"
This is currently a known issue due to a change that was made in MicroStation 2024, causing in incompatibility. Here are the options:
Option 1: downgrade your MicroStation version (for example the base 2024 release, 24.00.00.XX)
Option 2: wait for MicroStation 2024 Update 2, which is planned to be available by early 2025.
Option 3: use the Standalone version, which has the ability to work with CAD files, and could be an alternative to using MicroStation integration. See: CAD Functionality in Standalone as an Alternative to AutoCAD or MicroStation Integration
