| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Uninstalling |
| Date Logged & Current Version |
Oct 2024 24.00.01.152 |
AutoPIPE abruptly stops installing and displayed and "0x80070652" message. Or, log file has the following:
Error 0x80070652: Failed to uninstall
Failed to install ME101 translator (1.00.00.11) with error code 0x80070652.
Another installation is already in progress. Complete that installation before
proceeding with the install.
Why and how to avoid it?
The error 0x80070652 ("ERROR_INSTALL_ALREADY_RUNNING") is caused by one or more stuck msiexec.exe processes. The cause of the stalled process remains unclear; however, ending those processes is likely to rectify the problem.
Use the following steps:
If this procedure does not help, please search the internet for "Error 0x80070652 – Another installation is already in progress", example here
To Fix Failed to Install with error code 0x80070652 Another installation is in progress
