| Product(s): | AutoPIPE Vessel | ||
| Version(s): | 45.00.02.004 October 2024 |
| Area: | Lifting Lug | ||
How to add two tailing lugs in vessel?
Heavy weight equipment with one tailing lug may fail in lifting analysis. To distribute the loads user can add one more tailing lug on the vessels.
Add tailing lug from Support<Lifting Accessories>Tailing Lug. You can choose available orientation or enter new value in Orientation 2 , refer below image for reference.
Then you will see two tailing lugs in the 3D model.
