| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Report |
| Date Logged & Current Version |
Oct 2024 24.00.01.152 |
What is the meaning of "preload" in the output for a rod hanger?
On the side of the variable spring being installed is a scale with a set of arrows. This is the preload that the spring is set to when installing it into the Cold /Hot position.
