| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Warning |
| Date Logged & Current Version |
Oct 2024 24.00.01.152 |
The following message appears when running a model consistency check in AutoPIPE:
W726-17: Soil option not available
Why?
How to avoid?
Please see the following product feature page in AutoPIPE help:
This will document the feature that you are able to use based on the license configuration currently active in the application.
In an example, the model requires the use of Soil features, and the License is currently configured to Standard AutoPIPE
Question: can these features be used?
Answer: No. see the chart and review for all soil features. These commands are only available in AutoPIPE Advanced and Nuclear
